My self propelled mower won't self propell. I've replaced the clutch. When I try to engage the drive the clutch plate stops turning.
Thanks for your reply. The pulley wasn't turning when the drive was engaged so I removed it and put it back on, but didn't tighten it so much that it wouldn't turn. It seemed like a strange set up... the bolt was fully threaded and the bushing was between the pulley and the bracket. The bushing wouldn't go into the center of the pulley??? I would have thought the bolt would be a shoulder bolt going through the bushing inside the pulley. Does anyone know where I can find a parts diagram for my Ariens self propelled mower?
Thanks Mower Addict! I looked at the diagram and it looks like the bushing doesn't go inside the pulley? I'll keep fooling with it and maybe I'll be able to figure out what's wrong, if I do fix it I'll post the solution.
