New guy here, first time with a mower that has a drink holder.
I got a 42" riding mower a couple of days ago that needs things (head gasket, who knows what else after that?) and so far, I haven't seen the headlight operating, so I looked at a schematic and it shows that it "has a special alternator system. The headlights are not connected to the battery, but have their own electrical source." (in the link below, next to the diagram of the ignition switch).
Why would they allow the headlight brightness to vary with RPM? That makes no sense. Well, other than lower cost by not using a better voltage regulator. I haven't found a service manual with specs yet, so I'm working a bit blind on this. Gas had water and debris, so I drained/cleaned the tank, changed the oil, will change the fuel filter and spark plug today and order the correct head gasket ASAP.
My questions-
Will the alternator have a problem if I use the headlight + wire to activate a Bosch-style relay, then supply battery voltage to the lights through the relay so it's more stable? That way, the lights will only work when the engine runs, but RPM won't cause them to dim (as much).
I plan to check the bulbs for draw before doing anything like this but will use LED if the alternator is at the edge of its capacity.
I worked in car audio/security and as a marine mechanic, so seeing this kind of wiring makes my eye twitch.
Thanks, in advance.
My questions-
Official Ariens A175BG42 (96016002102) front-engine lawn tractor parts | Sears PartsDirect
Ariens A175BG42 (96016002102) front-engine lawn tractor parts - manufacturer-approved parts for a proper fit every time! We also have installation guides, diagrams and manuals to help you along the way!
www.searspartsdirect.com
Thanks, in advance.
