Repairs Ariens 15/40
AltonR
I just bought an Ariens 15/40 used .
The guy said he thought the belt tension springs were weak . The blades slowed down in high grass .
Belt seem's tight to me so my question is ...... does the electric clutch either work or not work or is it possible to be going out in stages ?
I checked and it does have 12 volts to the clutch . At first it only slowed down in heavy grass but now it does not rev up at all .
Figured it out and maybe this will help someone else .
I pulled the deck to get to the clutch ........when I release the clutch engaging lever or whatever that thing is called it came off in my hand . The bolt holding it had sheared off .
Replaced the bolt and all is well .:dance1:
