arien control cable
last2letudwn
Hi all,
I am new to this forum. I am hoping someone can help me out. I have a walk behind ariens mower deck that I am putting a new engine on. The engine is a tecumseh model tvs-105 53046G. It is a tecumseh made for ariens (ariens logo is all over the motor)
I can't seem to find the blade control cable for this engine. Long story short I need to know which model ariens used this engine. Once I know this I will be able to look up the right cable.
Thanks
Hi all, I am new to this forum. I am hoping someone can help me out. I have a walk behind ariens mower deck that I am putting a new engine on. The engine is a tecumseh model tvs-105 53046G. It is a tecumseh made for ariens (ariens logo is all over the motor) I can't seem to find the blade control cable for this engine. Long story short I need to know which model ariens used this engine. Once I know this I will be able to look up the right cable. Thanks
Most engines use a standard cable that fits many mowers and engines.
Unfortunately, the common cable with the little platic, tapered piece that connects to the control bracket won't work. This engine bracket needs a cable with the little s hook that is held on with a little screw. If I can figure out how to post a pic of the bracket, I will post one
Good thinking a pic would help.
I know the cable your talking about I can get you a part number when u get home
