PTmowerMech
- Apr 16, 2018
- 397
- 3,030
I was going to replace an old light socket today. It was just sort of hanging by the wires. The LED I bought for it, wouldn't screw in far enough to connect. (just a normal bulb screw in type), So I thought I'd change out the whole thing. I'm fairly knowledgeable about wiring, so turned off the light switch, undid the wires, and decided to check which one was hot. I've repaired some other wiring in this old house, and found the white was the hot and black was neutral. And sure enough it was the same. Except there was an even bigger problem. With just the light switch off, I was still getting current through the white wire.
So here's how the wiring went. From the breaker box, it went up through the attic where it was spliced. One went to the plug by the washer, the other went to the light socket first, then onto the switch.
I screwed up when I unhooked the wires, because I was under the assumption that the wiring came through the wall to the switch first, from the breaker and then up to the light.
I can't figure out how on earth he got the light switch to power the light, when there's only two wires (a black & a white) going from the splice, through the light socket and then ending at the light switch.
I have three wire nuts laying there when realized, something ain't right. And that's where I got lost.
