arkmail200
- Jul 12, 2023
- Threads
- 1
- 3
If I spray starting fluid into the carb it will stay running, but wont start otherwise. I disconnected the incoming fuel line, and fuel flows freely by gravity, so fuel filter/lines are good. Prior to it stopping running, I was having to run it with almost full choke, so it seems it's a fuel issue.
I know the round fuel pumps with 3 fuel line connections, you can disconnect one hose and crank to see if fuel comes out, but I dont think you can do that with this one, can you? I'll start the process of buying a $10 rebuild kit, but was just curious if it could be tested somehow. I took it apart, and all the parts were intact, but I suppose the springs/rubber could be worn out.
I'm guessing carb could be an issue as well... I've cleaned/rebuilt quite a few of the basic unscrew the bowl carbs, but never one of these types that feed two cylinders. I'd rather not have to mess with the carb, but I guess if the fuel pump isn't the problem, I'll have to.
I guess one other thing could be bad gas, but I'm pretty sure any gas from last season has been depleted by now.
Thanks for any advice.
Briggs & Stratton 42E707 2631E1 9708015B
