Does anyone know where the breather is on a 27hp Courage.It's not in the valve covers....in an engine blowup it shows one under the flywheel.I read a service bulliten from Kohler that said breather elements could cause oil to pass when on hillsides.I have to under fill my Cub 1554 about half way down the add / full mark on the dipstick.If I fill to the top,it will smoke until it lowers itself down to the area.Thanks!:confused2:
