Last Fall when I put the mower away I drained the carb by shutting off the fuel line and running it dry. Today, I am trying to get it started for the first time with no luck so far. I have removed the air cleaner and used a small syringe to squirt some fuel into the carb. I pull the starter cord immediately and she fires up and runs until that small amount of fuel is used up, about 3-5 seconds, and then quits. I repeated the process several times with the same results each time. I have checked to make sure the fuel line is open. It sure appears that we are not getting any fuel feeding the carb. When I performed this procedure, I had the choke engaged fully. Any tips on what I should try next? Thank you in advance!
