Hitechluddite
- Dec 14, 2018
- 24
- 90
We traded a pickup load of firewood for this. Previous owner says it has an oil leak somewhere around the oil filter and he started to remove the engine to effect repair but then decided to buy a new kubota and just pushed the JD to a corner of the garage where it sat for a couple years. #1 son re attached the motor to the frame and re connected all the wires with the exception of one of one wire coming from the coil shown in the picture. This wire measures .9 ohms to ground and we checked continuity as we rotated the motor by hand and saw some deviation in the continuity. Checking from the coil wire to the coil pickup housing is 9.8K ohms. Looking at the wiring harness and parts manuals I can't tell where this wire would go and there is nothing within reach of the existing harness for it to connect to. Any help Much appreciated!
Serial Number is M00245B162039
