Is the customer wanting you to bid it on a per cut? Or a 12 month contract?
Are you going to have to blow and maintain parking lots?
How long will it take you to cut it one time?
What are you going to have to do beside cut grass and Weedeat?
Are you going to have to keep shrubs trimmed?
How often will you have to trim shrubs if you do?
Those are the variables you will have to keep up with......
Good points all. No shrubs as far as I know. I would guess that unless the owner makes unexpected demands I'll only be blowing trimmings off the front lot.
The biggest problem here is that I don't have a clue how long it would take to mow that field. I don't even have enough experience to make a ballpark guess.
