another one...
reddragon
just bought this for $150....has a newer 18 hp briggs twin...hydro..42" deck...will need a front grill and a clean up.....and has a bagger..
Looks just like mine but with the bigger engine. Mine don't have the trailer hitch - still just a lawn mower. I had to do some jimmying around with it because one day it just stalled. I added a switch to actuate the fuel solenoid at the bottom of the carb. I changed the speed cable, mine was all rusted out. Anybody know what the output from the magneto is? [voltage?] Must be around 13 volts to charge the battery. The two back tires are original issue but with slime tubes inside. One of the front tires has a slime tube inside, the other one is a brand new tubeless. The speed nuts that hold the cowling to the frame broke off in front but I made some L brackets out of angle iron to keep that end down.
i like the front end ...but that damn plastic breaks so easy.....i had the starter break a magnet off inside and it shorted......frying my wires..had to do some surgery.....but now it works...the hydro's brake stopped working...but im selling it for $330 because im overloaded with mowers
