SeniorCitizen
- Aug 28, 2010
- 132
- 2,183
locks up, with the starter being stuck in the engaged position. I loosened the starter to allow it to return to the disengaged position.
That starter pinion gear should not be binding in the flywheel.
If the starter is mounted so a shim of a few thousandths can be added to move the starter away from the flywheel a small amount I'd be trying that.
