Update: I followed recommendation/help from below, cleaned alternator, tightened everything and seems to be running great again. Thanks all
Hi
I had a shop replace a motor on my 1995 Murray so the wire colors might not be correct!!! My motor was running erratically then would not start. I think the issue is my motor only had three bolts attached to the frame and was shaking and one of the wires attached to the alternator came off. One red wire which seems to have a diode on it is still attached. But another wire (I think it should be black but it is red) is just dangling. Before I notice this loose wire i could sometimes get the mower to start so I was wondering if the loose wire was grounding itself and allowing the motor to run briefly. The question is do I need to pull the fly wheel and see if I can reattach this wire to the alternator or can I ground it somewhere without pulling the fly wheel? If I don’t get an answer to this thread I’m gonna pull the fly wheel and check out the alternator and maybe replace it if I have to. I’m afraid if I try to ground the loose wire it might make all the metal parts of the mower subject to dc shock. :-(((.
Hi
