Allthread between the two hydro gears is loose?
mdecker42
2015 Dixie Chopper Magnum 2460HP
Doing maintenance on the mower and found a piece of all thread between the two hydro gears that missing the possible outer nuts and the inner nuts were not doing anything. The allthread had actually almost fell out.
I am not sure what this is for or how to fix it? I can't even figure out what this dang thing is called or what it does. All internet searches have came up empty.
Please Help!
Well according to the IPL the all thread is a 3/8-16 x 13" The outer nuts are 3/8-16 flange nylon lock nut grade A. I would use Grade 8 inner nuts are not shown but should also the same flange nylon lock nuts.
Sounds good. Is the rod just to stabilize the bottom of the hydro gears? If so that is a simple fix, but i did not want to do something that might mess them up.
