Airens 42 inch mower hydralic
Hockey1
my nebor bought a airens ikon 42 inch mower -Why is there no place to put hydraulic fluid -I only use hysquvarna zero turn and there is tank for hydraulic fluid for the hydros
Because they are considered sealed units. Appears to be HyroGear EZT units. They must be remove in order to change the oil.
From service manual
FLUID CHANGE PROCEDURE
This transaxle is factory filled, sealed and does not require oil maintenance. However, in the
event of oil contamination or degradation, oil addition or change may alleviate certain performance
problems.
1. Remove the transaxle from the vehicle.
NOTE: If removing the wheel from the transaxle, do so by removing the four (4)
lug nuts. Do not remove the axle/hub nut.
2. Clean the oil fill port area of any debris.
3. Remove the oil fill port fitting.
4. Position the transaxle so the oil will drain completely out of the housing.
5. Fill the transaxle at the oil fill port according to Figure 4.
6. Install the oil fill port fitting.
7. Purging will be required. Refer to the purging procedures on Page 12.
8. Recheck the fluid level once the unit has been operated for approximately 1 minute.
