Advice on replacing 52” mower deck spindle
chrisn710
I’ve got a Raptor w/52” deck. I need to replace the middle blade spindle. My problem is I can’t figure out how to remove the nut holding the pulley to the top of the spindle. I’ve used a pneumatic impact wrench and an open ended wrench w/cheater bar. The nut loosened just enough to make the spindle shaft loose, but no more. Now I am having difficulty securing the shaft so I can put loosening torque on the dang nut. I’ve attached a picture. Any advice?50783759-1954-4FFC-8B5E-A9D8338FA499.jpeg
That nut is a thread deforming nut. As said block the blade and use a good impact. Otherwise you are probably a pull bar with a cheater extension to remove it. After removal you are going to need to re die the spindle shaft threads.
Now if the spindle shaft is a through bolt then it is a little harder to remove but a strong impact can still get it off.
gainestruk
I'm assuming you already have new mandrel, last one I bought came with pulley already on it ?
The Chairman
Put the blade back on the other side and brace it.
