Ok I will keep this short as possible. I bought a Husky 525lst yesterday and the clutch was very loud, sounded like a loose screw in a tin can. So I took it back to the dealer New and they said it was normal but I wasn't happy so I traded for the Echo 2620T. They weren't happy but did it, brought home used for 10 mins worked great until it started to sound like gears are grinding in the head area. My question is this.....I would think that they would go ahead and replace it for me BUT if they try to take me down the warranty route...I'm going to be very angry if they pull the warranty route. Am I expecting to much?
Not your fault that happened, I once bought a NEW water-heater at Home-Depot, got it home, opened the box and found a big dent in the cover above the elect. conn. point, took it back, they gave me another, got home and,.. no-schitt, when I opened the box, I found a OLD beat-up heater, I about schitt in my shorts ! I figured they would think I was tryin to pull a "fast-one" on them, lucky I had my old water heater, I took both of them back and told my story... the sales-guy said it does happen, A-holes put the old water-heater in the box that was carefully resealed (on the bottom) then take it back N get a refund saying they changed their mind or whatever, in essence getting a free water-heater, Sooo
they dragged out another 1 for me, but this time we opened the box in the store to make sure it was OK .. I hope YOUR dealer is as understanding as mine was ..... I would take it back, explain the issue ( NICELY) and IF they give you a new unit, start it at the store hopefully you won't have to go through a bunch of B/S !!
