I'm no expert but can tell you that the more robust construction of the Tiger Cat along with the larger wheels that come with the 52" model make a big difference on rough ground and steep terrain. I mow approximately 5+ acres of pasture with my 2013 Tiger Cat 52" and depending upon how detailed I mow around trees and in gullys I can spend 6 hours a week each time I mow and look like an old racoon by the time I finish due to the dust.
The more you are mowing on lawn conditions the time it takes to mow goes down considerably but rough ground and obstacles is what it is. I believe with the amount of mowing you are stating you'll benefit from a commercial grade mower like the Tiger Cat.
Best of luck to you.
