ColdSteel777
- Dec 18, 2019
- 1
- 5
Hi guys my lawn mower engine ran without oil and it threw a connecting rod so I have managed to find the same motor although a few parts are different namely the pistons and oil splasher and the one block has a lever inside that connected to the carburettor on the outside that would be the used block . now my motor did not have much use when it broke the connecting rod so I would like to use that one as d one that I bought has very worn valve guides. So I want to make one motor out of these two. I have one good crank one good connecting rod I need advice on the pistons and oil splasher. I attached the pictures for you to look at and give me some advice on which ones to use thank you
