fairlaniac
I have my buddies Honda HRT216 SDA CGV160 mower that hasn't run for years according to him. I got it running but the hand control really doesn't do much for the engine speed. It will choke and start but the difference between WOT and idle is very minimal. Also as it runs after a few minutes it all of a sudden will just die off. I have the air cleaner off while doing this and when it goes to die it has a slight pop. I do not know what my buddy played with on adjustment nor do I know what good running adjustments are. I down loaded the mower manual and engine manuals but neither really describe the components well or detailed adjustments. I checked the float and it moves freely and fills the bowl. When it shuts off there is still fuel in the bowl. I thought maybe it was just running on the bowl fuel and shutting off but tha tdoesn't seem to be the case. So if you can, please throw some ideas at me. I an very mechanically inclined, especially with autos but mower I never messed with too much.
Thanks!
Thanks!
