Adjust Suspending Deck Cable / Belt replacement for a RER .
MICH27
  • / Adjust Suspending Deck Cable / Belt replacement for a RER .
I have a Old Snapper RER, with cable supported Deck, I bought it used ! I need to adjust the height in the back it cut too low
and replace the Deck Belt, which was broken last week !
Anyone worked on the Snapper RER and had some ideas how to do that Please lshare your knowledge !
From watching the gears in the bottom I think raise the engine from the mound and put the belt down would do, but Dont know
how to raise the DECK . How can I shorten the cable
Thanks
mechanic mark
Get model,serial,engine numbers, go to Snapper website then manuals.
MICH27
Re: Adjust Suspending Deck Cable / Belt replacement for a RER Snapper !
I finally figure on my own and replace the Deck Belt myself.
1- Deck Belt replace put transmission into 5 Gear , then depress the Clutch, then the bottom open for you to put the belt in the back underneath the engine
then loop the belt through the pulley in front and you all set !
2- Raise the deck by adding some small steel tubing spacer in the Back cable and turn the right bolt bar clockwise to adjust the height if the Deck in Front !
There may be other methods to do it ! But I find out this is relative easy, So I want to share with y'all if you have similar issues !
Cheers
