Adjust Snapper RER Shifter
Bill Tynes
I think my shifter needs some adjustment to keep it in reverse. Can someone give me a tip on how to go about this adjustment?
Billt23
Billt23
Chances are, your drive disk needs adjustment. There is a bolt to adjust how hard the disk "hits" the drive plate. Reverse is the first to go when it needs adjustment. Remove the plate on the back of the frame, and the bolt should be visible. (not sure, I've only adjusted the disk on my LT.....but I know there is a stop bolt to adjust how much tension is on the rubber disk on all of them.....)
This adjustment needs to be done from neutral.
