I hope this helps. The control lever will not go further than this position in reverse. It actually does go into reverse gear but like 1/8 mile per hour - totally useless.
The other is a side view over the right rear tire. You can see the shaft at the top (horizontal, then goes up on the left side) which is what the control lever looks like from below. Then it goes to where you see the bolts but adjusting those does not adjust lever travel.
I apologize for the delay in replying. I travel quite a bit but luckily without the mower.
