rbsmith6
- Jun 11, 2017
- 1
- 14
Where did you hook up to? I would like to jump into the ignition switch but witch wire? (see attachment)View attachment 28031
Donkman
Use the orange wire at the Switch.
Donkman
This is what I did on my HSD.
Lights on ebay http://www.ebay.com/itm/2x-4inch-18...e=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649
What is that black box on the front middle of your frame?
Has anyone found a rocker switch that will mount in the extra hole in the dash panel?? I bought a set of lights on Amazon last weekend along with this switch......... https://www.amazon.com/gp/product/B013TE56X4/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 but after receiving the switch & comparing it with my old hour meter it seems a little to thin and skinny to fit in the hole, was wondering if anyone had any better ideas?
Ah no big deal, I'm sure I'll find some use for the switch here sooner or later!! Went down to O'Reilly's this afternoon and found this switch.........Is there anyway possible that there would be enough space on the dash to cut out an exact fit for that switch you purchased?
This way you wouldn't lose out on the money spent on that switch and it could still serve it's purpose for what you brought it for, just saying.
If not, might I suggest that you make precise measurements of the actual area (maybe a small template?) that you would like to mount it in and make a trip to either an electronics store, Autozone, O'Reilly's, Lowe's, etc. and see it you could find a switch with an almost exact fit?
