Add on fuel filter for Troy Bilt mower and power washer?
There are no filters in your tanks........... 394358S is a good filter for what you want. Those are the white ones and will let gas pass thru perfect, the red ones are a bigger mesh inside and will let smaller particles go thru..... I order the 100 pack from my distributor and it is a Briggs labeled product like they put on their engines ....
394358S are 4 buxs at a mower shop........
Let us know Mon Ami ~!~!
You have it back-wards Bou... the WHITE ones are for engines WITH a fuel pump ...... read carefully in the description
No Boo Boo not these white ones..... They are for straight line systems..... The 691035 is for fuel pumps and is 40 Microns........
The one I said earlier is a 75 Micron...... It's exactly like the red one but colored white......
