Actual Manufacture Date of this MTD Battery???
evh
Does anyone know the actual manufacture date of these MTD batteries? This is an MTD battery (not original to my Cub Cadet XT1 machine). It did come out of another XT1 I bought and sold.
Anyhow, the recharge date on it is March-2017. You can read on the label they recommend charging the battery if it is being installed in a machine after March-2017. I wonder if that date is based on, say 3 months or 6 months after the actual date the battery was manufactured.
sgkent
it is at least 8 years old. replace it.
evh
Ha, I thought that would be the response. Yes, it doesn’t owe me anything. It still tests good (two different testers) and is still able to crank the Kohler 7000 22hp in my XT1.
I will likely replace it this year. Last year at times it would stop at the compression stroke and I would have to cycle the key off and then on again to get it to clear it and start the engine. I did clean the ground and starter connection for this year to see if that helps.
Mine is a 2018 model. I see the newer ones (with larger engines – Kohler 7000 series 24hp) come with a smaller AGM batteries rated at 210CCA’s where as mine is rated at 300CCA’s and tests at about that. I fail to see how replacing my current one with the ones they are currently using will start mine. I would also have to get a new battery tray insert.
Tiger Small Engine
If it is sometimes hanging up on starting on the compression stroke, check the valves for correct clearance and adjust as needed.
  • Like
Reactions: evh
Ozcub
My battery is 12 years old , and touch wood it still has enough life left to get me through Autumn/Fall and will maybe replace at the start of Spring/September
Currently attach trickle charger for half an hour before mowing and as Jackie Gleason said "Away we go"
Oz
sgkent
What happens if you stop some day in the middle of the mowing for five minutes and it doesn't have enough to kick it over - "now what do I do, push it home? It's 100F outside." Generally Lead Acid batteries are good for 4 to 5 years max, the average is 3 - 4. Starters can draw more current and burn up windings when the battery gets low. What does a starter cost compared to a battery? Or stretch it till it strands you.
Ozcub
Just drive the truck to where that may happen and jump start it
It will not get to 100f/40c until next summer 1st December here so I am all good
Oz
