Boudreaux In Eunice La.
- Jul 22, 2017
- 21
- 2,154
Me and my buddy talking on the radio LIVE about non ethanol gas............
https://youtu.be/ZM5LLUvMbr0
I'm in Houston. Native Texan. No starnger to coonasses... um Cajun folk. Or accents. Rock onWell we live in Cajun Country and got dat Accent. LOL.........
I put it on here because this is one of most read site on the forum.
All mowers and small equipment has a a warning now. No E 85 gas or your warranty is void.
Cars and trucks are being made for that stuff. I don't use any of at all. I use pure gas in all my stuff and tell my customers to do the same.
If you think I got a accent go to facebook and look up my nephew Landun Primeaux. He does funnier than ***** videos. Every now and then he has a few go viral with over a million views.......
Don't be too quick to blame the EPA. There huge bucks in ethanol. You don't buy the EPA, you buy the congresscritters.Wow..that'll sure wake y'all up an a Saturday morn............
When I lived in sunny Florida, gas was expensive enough, and non-ethanol gas was a buck higher and 20 miles away.
Since moving to south Mississippi 3 years ago, I can buy non-ethanol gas locally for less than the blended stuff back in Fla.
The blend is horrible on carburetors.
The ethanol absorbs water, and, if left in the carb to sit for extended periods, the fuel evaporates leaving the water to corrode susceptible parts.
Turns rubber parts and weed-eater fuel lines to mush.
I even had a can full that was so caustic that it ate the gas tank cap rubber gasket on my mower!
Mowers that wouldn't run due to ethanol gas having been left standing in their carb bowls were plentiful.
Outboard motor repair shops made a decent living off rebuilding ethanol fouled boat motor carbs.
And, if anybody wonders why the price of carb kits has gone sky high, it is because manufacturers have to use
gasket materials and o-rings that can tolerate the ethanol.........
Good old EPA
Your federal government...there to protect you from yourself in spite of yourself.... NOTE---NOT A POLITICAL STATEMENT !!
I have seen many articles/studies that ethanol production consumes more energy than it provides.
And, ethanol production diverts feed corn from cattle ranchers, driving up the cost of beef and any other
livestock which is normally corn fed.
I'm sure that somebody profits from ethanol production, but,gas mileage drops. so.......
Other than the lowered price of ethanol gasoline, the typical consumer may not see a cost benefit...
