first thanks for any info in advance.
I just picked up a used 616 with probably several hundred hours on it.
Where do I find the model number for the engine. It seems to run a little rich and I only found one adjusting screw in the center bottom of the front of the carb. It doesn't run smooth at any rpm, not bad, but not smooth.
I took the carb cover off tonight to see if it was gummed up or full of dirt but didn't see anything out of the norm. I sprayed the carb down and cleaned out what needle jet that I could find. I have a tube that comes off the front top of the carb that has a piece of rubber hose with a screw plugging it. What did this hook up too?
Not sure what I would call the brass tube that connects to the top of the carb that goes down into its own hole when the top is on, but it has several varying size hole, but it was slightly bent so I straightened out and reinstalled the top. Doesn't seem to run any better if not maybe a little rougher and richer with maybe some black smoke.
Thanks a bunch
Bob
Thanks a bunch
Bob
