I'm trying to get this hub off so I can replace a leaking axle seal. I have the wheel off and the clip. But this thing won't budge. I put some penetrating oil on it and let it set for about an hour. Then hit the center hole on the axle with the air hammer. And it won't budge.
It was leaking from the inside of the wheel.
I'm not sure about using heat because of the plastic axle cover. I will if I have to.
Anyone run into this? If so, how did you fix it.
