Lawnmower collector
Neighbor brought me a DR walk behind brush mower to fix. Drivebelt was soaked with oil and slipping, oil appears to be coming from the governor shaft, leaking just sitting not running. I ordered a new seal and took the governor arm off but there's no seal visible from the outside. Just a bronze or brass bushing that's pressed into the crankcase. I haven't replaced one before, is the seal installed from the inside or does it even use one? The governor shaft isn't real tight fitting to the bronze bushing. Engine Model 195707 Spec 0468-E1 Thanks
