8Fh12LB no spark
Brad S
Hi looking for some help. I have new coil and condenser and checked all my clearances and still no spark I’m baffled.
Hi. Make sure your breaker points are set at .020 when the cam lobe is at its widest point. you need a cut away fly
wheel with the magnets in it to set the coil gap at .010. you will have a spark at this time.
