Fish
yes, the solenoid is as simple as it can get. one big wire from the battery to the solenoid along with another smaller wire to send the battery voltage to the keyswitch....
One big wire from the solenoid to the starter.
One small wire at the base of the solenoid, when you turn the key to "crank", 12 volts is sent to this terminal to let the engine
crank......
crank......
