well, got it in today. 5 months to fix. wow. i have a mower just in time too. grass got 12" high. nailed it today. what an ordeal its been. and as it was, the tranny works fine but isnt exactly the same. but you know what? i can live with it. the gear pattern is the same, 5 forward/1 reverse. but the shifter guide off my old one doesnt match the pattern. on mine, you go back to a space and lift up and continue for reverse. the new tranny has shorter throws. meaning when you go all the way back to that cavity in the guide for neutral, youre already in reverse. im sure its a simple task of finding a guide to match the p/n to the new tranny. but its really just a matter of retraining the operator. its much cheaper and im just plain lucky to have found a new tranny to a 30 year old mower. THANK YOU RBI. and thanks again to all!
i will be posting a thread on how to tighten the rear axle thats loose and drooping. i went to service the rear right wheel, and i just pulled the axle out 1/2 way with the tire still attached! i quickly put it back in to mow the yard! anyone know off hand about those issues?
