Remove spark plug boot for safety, remove blower housing, top cover over flywheel, and clean everything by hand, no water or any liquids, use nylon bristle brush, smaller than toothbrush, can pick up anywhere, clean out debris & use shop vac etc. to pick up. Adjust valves per manual specs.
Unless this is a 4-stroke (doubtful) there are no valves to adjust, unless you mean the reed valve on the intake, which really does not have any provision for adjustment, it is either good, or bad, and if it starts when cold then the reeds are good. More likely you have bad crankcase seals (if 2-stroke). Cheap and fairly easy replacement.
I had put an older carb on the mower to try to correct the problem. After many tries, I put a kit in the original carb and it seems to be fine now. I don't know enough to understand what happened, but I am happy now.
Thanks for all the responses.
New twist!! After mowing and sitting awhile, noticed gas coming from the carb. I put new needle and seat plus adj the float. Good thing I like a challenge.
Turn adjusting screw out (counter clockwise ) 1/2 turn. It is set too lean causing a hot restart problem. Lawn Boy had a service bulletin covering this condition on these models.
