If your trying to get at the bushings in the driveshaft, remove the transmission as an assembly. There should be one bolt holding it to the deck from the bottom. The bolt may be hidden with dried grass crud. The snap rings just hold the plastic cover on the transmission.
Jeff
Jeff
