peteclark3
- Jan 1, 2012
- 47
Hey guys,
We have a Lawn Boy 8252 that used to run like a champ. It started running so-so, so we did a couple of things.. put in a new spark plug, sanded the points, checked all the connections, took apart and cleaned out the carb, put in fresh gas, and replaced the crank seal. When I put it all back together, I could get it to fire once or twice, even once I got it running at a low RPM, then it stalled. Same with starting fluid, just a fire or two. After a bit of sitting (week or two), and a re-clean of the carb, and new gas again, I can't get it to fire at all, even with starting fluid sprayed in the cylinder, and sprayed in the carb.
What's crazy is that the spark is bright blue.. so I thought it'd fire at least once given that I sprayed a bit of fluid in the cylinder... oh well.. any help would be appreciated! Miss this mower running well like it used to...
