wrldtvlr
- Jul 18, 2020
- 130
And a followup to my comment about washing with water. Came across this MTD Service Bulletin while researching spindle lubrication requirements (newer OEM spindles are sealed, so no lube possible). It makes a compelling argument for not washing the mower deck with water:
CLEANING:
Never use a garden hose, pressure washer or water spray* to clean around deck spindles – especially if the parts are warm from recent use. Using water around these sealed bearing assemblies may cause water vapor to be drawn into the assembly as the parts cool or the pressure force water past the bearing seals. Water inside spindle assemblies or bearings may shorten the life expectancy of these parts by contributing to rust build up and increased friction. The best method for cleaning around deck spindles is to use a soft wire brush, broom or plastic scraper tool. * Note: Cutting decks equipped with factory installed Deck Wash® systems are designed that the water spray is directed around the outside of the deck away from the spindle assemblies.
