Swapping over from Winter/ Snow Thrower to the Mower Deck 3461 I find it impossible to connect the "Traction Springs"?   I've gone through multiple cycles of "power fold" and "deck height" changes  including "adjusting (loosening) the traction springs" adjuster......  no luck.
I can get at best within 1/8" from the torque arm pin (using the special GH tool) but it isn't enough to get the outer of the 3 links, linked.
Anybody share some info?! Thanks so much! Hope someone has solved this and will share! TIA
Carl
Carl
