721D Power in left side weak
ROB57
I have a 721D that the organization bought this spring. The left side drive seems weak going forward, but has power going reverse. I checked the belts as advised in another post. Both belts seem OK. The Mower has around 1500hrs on it. Don't really know any history on it. I don't have alloy of experience with the zero turn mowers, but I don't think it seems right. Thanks
The oil level is almost exactly between the 2 marks. I was going to change the oil and filters. I don't know when that was done last. Do you adjust the rods? If so, make them shorter or longer? I played with the one on top a little bit already. Didn't seem to make much difference. Thanks
