718D Help Engine Swap
Mereslm
I have a 1989 718D with the Kubota D600 engine that finally hit its end. Everything else on the mower is fine. I have a buddy with a D902 that came out of a Toro Z-Master. I was wondering if anyone knew if these would switch out ok or if the configuration is just too far off. Thank you in advance
