Export thread
6th gear problem
#1
J
jj605v
Running into one problem. I have a very steep driveway and ride my mower down with my weed-eater to cut the grass on the private access road at the mailbox. Yesterday when coming bak up in 6th gear i hit a standstill and then the belt squeaked a little and then we resumed at what seemed like 6th gear speed. Any clue what caused this? Is it something that can be fixed?
its a 2004 murray select 17.5 42".
model 425001X8A
serial 7537236431d025
#2
reddragon
reddragon
your belt may be wearing out......but you should use a lower gear climbing hills :smile:
#3
J
jj605v
left one important thing out. I was actually coming up the driveway and blades were not engaged.
#4
reynoldston
reynoldston
You should have two belts one for travel and one for the mower deck. I would check the belt like reddragon said.
#5
J
jj605v
just replaced the belt last week. Its brand new. only 1 belt i know of?
#6
reynoldston
reynoldston
I guess its hard for me to picture only one belt but you know your mower and I don't. Did you get the right belt ? Just guessing? If its not the belt something sure slipping somewhere and you know that much.
#7
reddragon
reddragon
check for loose pulleys....especially the tranny pulley
#8
J
jj605v
I will do that.
#9
M
mullins87
You must have two belts. The deck belt will be on bottom and is the one you can see under the engine. The drive belt will be above the deck belt and probably up very close to the frame, maybe even between the frame rails. Infact, you may even have to remove the deck in order to get a real good look at it.
#10
reynoldston
reynoldston
I know all my rider mowers have three belts, travel, mower, and one that runs the deck, but it is his mower and who am I to say it has more then one belt. I find a lot of things out there I haven't seen.
#11
J
jj605v
of course im an *****. I have 2. Motion drive and mower drive. I guess i need to look at the motion drive belt huh!!!!!! heres the link to my manual. http://ubermanuals.com/product/murray-425001x8-12884 I only see 2 belts
#12
M
mullins87
Hey there, no name calling here, even if you are the one calling yourself a name. :tongue:
We've all been there at some point. You look and look for something, swear it's not there, only to go back and look again and find what you had been missing.
#13
reddragon
reddragon
i remember your other thread....you have 2 belts...you took good pictures before...can you take pictures of the worst looking parts of your tranny belt? :smile:
#14
J
jj605v
will do tomorrow. I swear I will try at least. Side note....its cutting great!!!!!!!
