K kjfishman Member Apr 16, 2016 #1 675 series on Troy built lawn mower won't restart hot, replaced the choke thermostat and still have the same problem. Ideas anyone?
reynoldston Lawn Pro Apr 16, 2016 #2 Check for spark when it wouldn't start. Ignition coil will act up when they get warm.
K kjfishman Member Apr 16, 2016 #3 reynoldston said: Check for spark when it wouldn't start. Ignition coil will act up when they get warm. Click to expand... After replacing the choke solenoid it starts much easier now to figure out the hot restart. Thanks I will try that suggestion.
