How in the world do you raise the seat on this mower? Its the time cutter with the battery on the right side under a cover. I need to get at the parking brake switch.
Can’t be raised, must be removed. Since you didn’t supply us with the model and serial numbers for the unit, I’ve just attacked the newest service manual to help you out. https://www.toro.com/getpub/182206
