I've owned a GSX XT3 with a 60" fab deck for a year now and cannot get the deck to cut level. My lawn is uneven and there is a section where I have to cut across the hill, which is fairly steep. When I do this, the downhill side of the deck scalps my lawn. It also happens when I go over an uneven spot and the deck drops lower on one side or when turning sharply. Yes, the anti-scalp wheels are in the lowest position - that's the first thing I did when I bought the mower. I've tried leveling the deck countless times, but it makes no difference when cutting across the hill or on an uneven spot. I've contacted the dealer a couple of times, but all he tells me to do is to lower the anti-scalp wheels.
I used to mow my lawn with an 1863 with caster wheels on the mower deck and it cut perfectly even. I never had a single problem with that deck. The deck I have now is designed differently in that there are no caster wheels.
I've searched online for a solution to this problem but can find little to no advice or information. I read a post where someone added a caster wheel just behind the discharge chute to be able to cut across hills and I've read posts where people have added a block or truck bump stop to the deck lift.
Is this a problem that can be fixed or am I stuck with a deck that won't cut level on uneven ground?! Thanks!
