6 hp briggs
1chevyman
Ran fine a couple weeks ago now won't start,has no spark but is getting gas, changed plug
Will need engine model, type, and code to determine what the engine looks like to give repair suggestions.
DaveTN
In general, with any engine that is not getting fire and has a kill switch wire, ..Look at the coil and remove the clip holdilng the kill wire and then check to see if you have fire. Usually the kill wire is grounding out somewhere between the coil and the switch.
