pugaltitude
- Jan 11, 2012
- 7
- 1,142
No the backing plate does have the horseshoe channel. All I had to do was take the plug out and put in the bulb. When I push the primer a squirt of gas does shoot up the main jet.
Could the compression release system be screwed up?
No nothing to do with compression release.
Is it pushing up enough fuel when priming?
The back plate was common for warping and air would escape as the gasket was not completely sealed.
Add another gasket.
Sometimes you can get what looks like fuel coming up the emulsion tube but all its doing is going back down when you let go of the primer.
