Ok I had to replace a short block on a duraforce due to a rusty connecting rod bearing from being stored outside, anyway on another site someone is claiming that some dura-force's use a bushing instead of needle bearings. The one I had apart did have a needle bearing no doubt about that. Seems that a needle bearing is a much better idea then a bushing. I cannot believe that some dura-force would have needle bearings and some would not. Can anyone confirm this?
