R Rivets Lawn Royalty Community Leader Joined Mar 11, 2012 Messages 16,295 May 25, 2020 #11 This manual should help you set the governor. https://docs.google.com/open?id=0B6NaqjIxWV1ycG8wd0s3Z2Q2X00
Mkala Well-Known Member Joined Jan 5, 2019 Messages 140 May 26, 2020 #12 Great, it's quite experimental making about the same bowl system from pictures They are usually rated at 3600RPM for max power, with a lot of variations depending on application, air cleaner. Peak torque is at 3000RPM, Idle is at 1750.
