On those models, in the top of the fuel tank, is the carb "bowl". And those over time can get rusted out, and develop
holes, even small ones, and not hold gas, or may hold gas for only a short while, and let the thing only run on choke, as the fuel leaking out leaks too fast to let it run on anything but choke.
I have repaired tanks in the past by removing all of the rust, and patching the cup with JB Weld, as a decent redneck repair.
Not sure about long term results.
