590v cam timing
85harley
I am a new member and need some advice. My cam gear broke and the timing mark was destroyed. I would like to know which cylinder is number one and how can I be sure the new cam is replaced in time .My mower is a 1996 John Deere 345. Thanks
Jack17
In general, the cylinder that is closest to the front of the engine is #1. As far as the cam on the main crank should have a mark (a hole or dimple) directly and dead center on a key-way. The valve cam should have a hole thru and thru. Those are your timing marks.
85harley
Thanks for the reply. I have not found the mark on the cam. I am thinking the destroyed part of the cam is where the mark is. The crank has been turned and I am afraid I will install the cam a half turn out of time. I am thankfull for any help I can get.
Jack17
The timing mark on a cam is going to be directly on the tooth that is right above a key-way cut.
reynoldston
T The crank has been turned and I am afraid I will install the cam a half turn out of time. I am thankfull for any help I can get.
This is impossible if you get the cam gears on the proper timing marks. The camshaft turns haft the speed of the crankshaft.
85harley
Thank you so very much. I knew that but over thought it and got cofused. I will blame it on my 66 birthday coming up in April.
reynoldston
I know what you mean, old age does it to you with a lot of things. I am 10 years older then you. The older you get the more pills you have to take and you can't reminder what you did yesterday. So join the old age club and enjoy your senior discounts. :thumbsup:
85harley
I know what you are talking about, I have had a heart attack and take a handful of pills each day along with two or three each day for my diabetes. I am thinking I need to get one more pill, maybe a blue one. Have a great day.
Jack17
Go ahead and take the blue one but if (you know what) lasts more then 4 hours call your doctor right-away!!!:rolleyes:
